Old 26-09-2006, 19:08
s12Rob's Avatar
s12Rob s12Rob is offline
Default s12 mk1 and mk2 engine
what are the differences with these engines? ive got a mk2 and puttin a mk1 engine in
Old 26-09-2006, 19:36
nothing much. Just different oil feed line to the turbo.
If you can get the oil line with it that would help you alot.......
Old 26-09-2006, 20:40
Dr Silvia's Avatar
the ancillary pullies are different too
Old 26-09-2006, 21:37
s12Rob's Avatar
pulleys aint a prob as ive got new mk1 and mk2 belts. im putting mk2 head on mk1 bottom, how will i get this to work
Old 26-09-2006, 22:54
mk1 and 1.5 have got mechanical valve system mk2 hydraulic ones, right?
Old 27-09-2006, 00:03
wrong Alundra.
As dr_silvia has just pointed out the pullies are different including the bottom pully but they are all interchangable
Old 27-09-2006, 09:27
thats not standard mk1 or mk2. I think thats been fitted at a later date or at the very least it was not available in the uk.
Maybe 30psi would know about it,i havnt seen it before.
Old 27-09-2006, 09:54
Sounds like a CA20 head to me
Old 27-09-2006, 14:12
Sure it came from a 1.8 turbo, but works with my motor; more than 2 months i ran with it .
I even saw CA20E with mechanical valve system.
Old 27-09-2006, 14:16
OK, well what cam has it got?
I can tell you now the CA20 cam is crap. The CA18 cam in the CA20 head still isn't at its best, unless you use the different ratio rockers from the CA18.
Francais :
Quelle cam a t'il ?
Je peux te dire maintenant que le CA20 cam c'est de la merde. Le CA18 cam dans la tete du CA20n'est toujours pas la meilleure solution, a moins que tu utilises un ratio different du CA18
