Old 01-11-2007, 10:26
docertabum's Avatar
docertabum docertabum is offline
S12oc Newbie
docertabum is an unknown quantity at this point
Exclamation High fuel pressure
Guys, I need your help. I tried to solve it by myself, but without result. I can't crank up the engine. I found out, there is a higher pressure of fuel then stated in manual. The sparking plugs are totaly floated with gas... Without even litte sign "ignition". I hope you understand Do you have any suggestions, pleeeese? I have FJ20E engine. Btw. all that started when I got home and tried to park my cars. But the engine sudednly stopped. I found out my powersteering pump was jammed as well and of cource the belt was burnt in one place. Could there be any connection between those two "events"?
Old 01-11-2007, 11:52
the bearings are probly siezed on your power steering pump, nothing to do with your other problem, which will be your fuel pressure regulator, located near the fuel rail, they are sperate on the fj20e, i have about 3 spare, if you need one let me know.
Old 01-11-2007, 17:16
docertabum's Avatar
S12oc Newbie
is there any way how to test FPR, if is ok or not?
Old 01-11-2007, 17:21
yes you can put a gauge in the fuel line.
Old 01-11-2007, 17:23
docertabum's Avatar
S12oc Newbie
I did it... the pressure of fuel was 2.7-2.8kPa in idle situation... normally it should be somewhere around 2kPa I think....
Old 01-11-2007, 17:28
not sure about kpa, but it should be around 37 to 45lbs.
Old 01-11-2007, 22:06
old-and-rusty's Avatar
For the FJ engine fuel pressure check, the s12 manual states:
at idle approx 206 kPa (or 2.06 bar or 2.1 kg/cm2 or 30 psi)
the moment throttle pedal is fully depressed approx 255 kPa (or 2.55 bar or 2.6 kg/cm2 or 37 psi).
Hope that gives you enough different pressures to go for ....LOL....
Regards,
Ian.
Old 05-11-2007, 10:17
docertabum's Avatar
S12oc Newbie
just for information... cost of FPR? do you send abroad? Thanks!
Old 05-11-2007, 16:29
ChEsTeR ChEsTeR is offline
You can buy an aftermaket one in your country it will be much cheeper.I Poland its about 50 EUR.
One like this
http://moto.allegro.pl/item264709963...liwa_f1_z.html
Old 08-11-2007, 10:06
docertabum's Avatar
S12oc Newbie
One like this
what-a-fancy regulator... It would be coolest thing in that car.... except orange chassis with black stripes )...
btw. guys, who have FJ20E engine... what did you tune in it?
warning - stupid question: I have to go to check CO emission. I pray everythign will be ok, however I'd like to know how could it be adjusted in S12 if needed?
