Old 20-04-2009, 13:19
serendipity123 serendipity123 is offline
serendipity123 is an unknown quantity at this point
Default turbo woes
ok i have turbo problems.
the two parts of the turbo appear to be loose, if you look at the youutube videos you can see the intake is loose and not connected to the exhurst side tightly, this is also letting gas'es escape from the join.
now i've taken it off and it looks like its a twist fit ?
http://www.youtube.com/watch?v=P65xP2lvMwI
please give me your advice
there are other videos in my youtube of it running
Old 21-04-2009, 14:23
yeah. this can be quite common.
the exhaust turbine housing is connected to the bearing carrier housing via a large circlip..
Either the housing or the circlip has worn away with age and nowthe circlip does not fit correctly
you need to either replace the circlip and/or housing or replace the turbo.
I had the same problem once. I welded the housing to the centre bearing carrier nearly all the way round and it kept it gas tight. ( bodgetastic!)
