Old 27-03-2010, 19:42
PureButeS12's Avatar
Default dump valve fitting / boost problem
i've just fitted a dump valve to my ca18et S12. the valve isnt dumping & my standard boost gauge is staying around zero. i have plumed the vacume hose to the blanked niple next to the clutch master cylinder as discussed on a previous threat
the forge dump valve was off a s14. is it not dumping or reading boost beacuse the spring is too hard for my puney 7psi or have i connected the vacume incorrectly?
any help would be a great help
Old 27-03-2010, 19:44
irish s12's Avatar
Have you got a picture of the way it's connected?
Old 27-03-2010, 19:49
giz 5min & i will have
Old 27-03-2010, 20:02
actually scratch that, my dad's F'd off with the camera GRRRRRR! i'll have to wait until tomorrow
Old 27-03-2010, 22:04
is the car actually making boost?
Old 27-03-2010, 23:34
i dont think so, its hard to tell with such low boost as standard? possibly not. i'm goin to have a good look over it in the morning... could a dodgy vacume prevent the turbo from working?
Old 28-03-2010, 13:29
the tansparant hose is my vacume, is this to the correct place?
Old 28-03-2010, 14:49
yeah thats fine. Unplug it and just check its sucking at idle. there could be a block
Old 28-03-2010, 16:44
i've just had all of the boost pipes off & found that the hose on the actuator was split, i've replaced it & reinstalled all the boost pipes but the boost gauge & dump valve are still not working???
does any1 know if the problem is because this dump valve is off an s14, is the spring too hard for 7psi to move?
Old 28-03-2010, 19:58
**update**
i've changed the spring in the dump valve for a lower psi one (donation from a mate) but still no PSSSSSSSHHHHH!
after further examination, the vacume is in the correct place & sucking good, boost pipe are tight & secure, actuator hose replaced & secure, but boost gauge is not budging?
i've noticed the arm on the actuator is not moving when revving?
