Old 19-09-2010, 19:55
Kevin Kevin is offline
Kevin is an unknown quantity at this point
Default Subframe & LCA info needed
For my S110 project I like to know some measurements of the suspension of the S12-chassis, can anybody give me this info?
The picture below are 200SX S13 items!
Mounting-distance, see picture below:
Distance between control arm mounting:
Length of the control arm:
WWW.TATI-MOTORSPORT.NL
Old 19-09-2010, 20:21
i can do the top 2 for you in the morning as i've got a front subframe on the back garden mate.
Old 19-09-2010, 21:15
That would be great! Also for sale?
Old 20-09-2010, 09:30
in inches top one is 30 1/2 inch, second measurement is 28 3/4 ish inch.where are you at mate ? as postage could be expensive with the weight.
Old 20-09-2010, 11:22
Thanks a lot!
Subframe to chassis distance:
S110: 72 cm
S12: 30,5" = 77,50 cm
S13: 77cm
Subframe control arm distance:
S110: 56 cm
S12: 28,75" = 73 cm
S13: 67cm
Old 20-09-2010, 17:23
For my S110 I'd like to upgrade the steering system to a S12 - S14 system (rack-pinion", because now the "recirculating-ball or pitman' steering system is in the car.
I've the complete S13 front suspension system including the steering-rack, but I don't think the S13 subframe can easily fit. So that's why I'd like to know the measurements of the S12 subframe. But it seems that's almost the same as the S13 subframe.
And second, I've a also a blacktop SR20-waiting to replace the L18 engine! And I know the SR20 fits in the S13 subframe...
Time to go back to the drawing table
Old 20-09-2010, 18:48
Are you sure about that 28 3/4"? Because then a S12 would have more trackwidth than the S13?
Old 20-09-2010, 19:04
sorry mate, its 27 3/4, was'nt awake this morning.
Old 20-09-2010, 19:14
Or maybe 26 3/4? because then it's the same as the S13?
Old 20-09-2010, 21:16
no deffo 27 3/4, i've measured it 3 times now, was half asleep this morning, checked it twice with the wife, i'll take a pic of it with the tape measure if you want.
