Old 06-03-2014, 21:56
Default Headlight headache
Hey guys, I'm trying to get all my wiring checked and working prior to moving on with the project but I cant seem to get the headlights working. Side lights turn on fine but no headlights fire up. No voltage to bulbs, bulbs are ok.
Ive got a feeling im missing the headlamp sensor box but have no idea what it is and where to find the plug that it connects to. The manual says the connector should have 3 Orange and black wires, yellow/blue, pink/black, pink, 6 pin connector overall. I have a connector spare near the headlight connector at the battery tray but the cable colours dont match the manual.
Someone help me out please I'm pulling my hair out and im already going bald
Old 07-03-2014, 21:20
tim murphy's Avatar
hi big dave not to sure about your problem not that hot on wireing take a pic and i will check with mine cheers
Old 09-03-2014, 19:48
Thanks tim, the connector im referring to is this one:
Im getting some proper wierd s**t now.
p/s headlight comes on
d/s never
d/s side light always comes on
p/s side light intermittent
when stalk is in headlight on position can hear humming from wiper motor, when wipers turned on headlights keep going up and down. I've made a major co**up somewhere.
Tim i'd appreciate it if you could tell me what goes onto that connector! Cheers guys
Old 09-03-2014, 19:49
Just thought i'd mention, i've opened up the stalk and it is operating ok, making proper contact, tested with a continuity tester
EDIT: Found it in the manual
Old 09-03-2014, 20:22
tim murphy's Avatar
not sure bigdave that one near the battery connects to anything but will check on my tomorrow cheers
Old 10-03-2014, 19:49
An update. The diode near the alternator loom was gone, bridged that and now the headlamps stay on with ignition on. Other diodes are ok.
Cleaned and connected up all the grounding points, now the wipers work fine without disturbing the headlights.
Still the headlights are playing up. Left lamp turns on when stalk is in second click position, no high bean when stalk is pulled back, main beam cuts out and no high beam. Right lamp shows no lights at all.
Both diodes are ok. Any clues people? Tim mate any chance i can borrow your stalk?
