Old 21-06-2006, 22:13
tish tish is offline
S12oc Newbie
tish is an unknown quantity at this point
Default turbo timer
hi pepole me again im tryin to fit a turbo time but not havin any joy does any1 know how to fit one or know what wires are what behind the barrel there is a black with yellow line a black with white line a blue and white with black line thanks
Old 21-06-2006, 22:18
adzs12's Avatar
adzs12 adzs12 is offline
Forum Regular
What make of timer is it ??
Old 21-06-2006, 22:33
S12oc Newbie
cant remeber the name got it from halfords there is a red wire blue wire yellow black and brown i know the brosn for the hanbrake
Old 21-06-2006, 23:41
Dr Silvia's Avatar
same one we wired into adam's car then
the white wire with black stripe is 12v feed from battery
blue wire is accesory feed
black wire with a white stripe is ignition
the blue and yellow wire is the starter signal
hope this helps
Old 23-06-2006, 00:38
S12oc Newbie
i know this is prib gonna be the most dumbest question ever but do u know what wires go were off teh time like the blue and yellow
Old 23-06-2006, 01:43
Dr Silvia's Avatar
it should say on the instructions you got with them, but if ur still unsure you can scan them and send them to me i will tell you what goes where
