Old 07-08-2006, 18:30
ramzb's Avatar
ramzb ramzb is offline
ramzb is on a distinguished road
Default T28 Replacement
Need some help please guys. I'm replacing the T25 turbo for a T28 but not sure where the pipe between the turbo and the actuator goes. On the T25 it connects from the front of the turbo but on the T28 there is nothing to actually connect to, or am I missing something?
Old T25
New T28
Old 07-08-2006, 18:38
Back Seat Chatter!
you just need to tap that into any charged vacuum line.
Most people will put a valve on the silicone coupler they use and attatch a vacuum line to that.
it must be charged, and the closer to the turbo it is, the better since this is the signal for your wastegate.
Old 07-08-2006, 18:40
ramzb's Avatar
Cheers for that, I've got a ca18det and have the BOV plumbed into the valve on the side of the block. If I put a tee on this will that work?
Old 08-08-2006, 02:51
Back Seat Chatter!
um...yea, but from what I understand, you want a strong boost signal. by the time it's reached the engine, the pressure drop has gone down at least 2psi...
Old 08-08-2006, 08:38
Jeff Jeff is offline
Jeff is an unknown quantity at this point
If you can't find anywhere else then there is a spare nipple just behind the throttle body you can use
Old 08-08-2006, 10:18
ramzb's Avatar
Thanks for the help guys. Has anyone done this conversion coz it aint as straight forward as I thought it would be The oil and water feeds are in different positions. Think I'll go back to driving my AX it's less complicated
