Old 12-06-2007, 23:21
mr_turbo's Avatar
mr_turbo mr_turbo is offline
Default T28
Ive got my T28 and ive looked at fitting it bit of fuckin about but seems straight forward has anyoff u done it? i knw i need a s13 turbo elbow as the studing is different and also the boost pipe from the turbo and ova the rocker(if ne 1 has these plz let me know) and the oil pipes seem almost the same which is cool lol wot sorta pwer difference does it make? and will i get a lota lag?
Old 13-06-2007, 09:06
As you sound like you're running without an intercooler you won't notice much difference in power, however power delivery will be smoother and further up the rev range. It will be a little laggy though, not much to write home about, certainly won't make much of a difference on the street.
Have you changed the plugs as well? It's well worth looking out for an FMIC setup as that let's you crank up the boost a little and will make a difference to power output because of it. There were a few for sale not so long back, I'm sure someone will pipe up if there is still one available. Don't forget that it's also well worth uprating your fuel pump with these mods as it's less likely to lean out running on a Walbro and will save you a piston or two!
After that I'd start to think about making it stop/corner better. Pound for pound good quality brakes and tyres are unbeatable for performance gains, makes the whole thing safe too!
Old 13-06-2007, 09:15
What t28 have you bought?
Old 13-06-2007, 09:46
It's one off a Pulsar GTI-R
Old 13-06-2007, 19:47
mr_turbo's Avatar
yer from a pulser. wots a FMIC set up and wot plugs shud i use? soz if im being thick here lol its alredady lowerd n stiffend n i got pilot sports on! i wouldnt mind some nice shocks thou!
also im having problems mounting the actuator has ne 1 done this if so how?????? lol i also need a 200sx s13 boost pipe from the turbo as it is different from the siliva 1 n e ideas ???
Old 13-06-2007, 19:58
fmic=front mounted intercooler
