Old 30-06-2007, 14:48
Default front bushes
what parts are what
what part is the trailing arm bushes, and front tie rod.
the ones circled are what i think i need, i get a slight shudder from the steering when when i punch the brake pedal.
Old 30-06-2007, 15:11
they are the tie rod bushes, if you are going for the poly ones, you need the 280zx ones on there.
Old 30-06-2007, 21:32
i saw RichardK's post in the how to section.
2 x SPF 1483K - Front Trailig Arm bushes - £89 per pair
1 x SPF1485/25K - Front Anti Roll Bar to Body Bush, Kit of 2, 25mm - 11.02 per pair *** TO BE CONFIRMED - THEY MAY BE 24MM ***
4 x SPF 0927 - Front Tie Rod (strut bar) Bush - £5.35 each (£21.39 total)
8 x SPF 2092B - Front Anti Roll Bar Link Pin Bush, 10mm - £2.19 each (£17.84 total)
what part is the trailing arm bushes then??? are these above all i would need to stiffen the front apart from springs and shockers.
