Old 06-02-2008, 16:18
alundra alundra is offline
Default My compression test
Hi,
After a fresh rebuild (Nissan head gasket, head verified for skimming or not), my car smoke some white one throught exhaust.
So i check the compressions (motor on heat):
cyl1:
cyl2:
cyl3:
cyl4:
In order to fix if the turbo leaks some water in the exhaust, the water line which feed the turbo return to intake manifoild.
Still smoke, at idle, at middle throttle.
I notice some smoke -grey- in exhaust gasket area (head/exhaust manifoild? or manifoild/turbo?)
No shaft play at left-right a few front-rear about my stock T2.
What do think about?
P.S: i'll order sooner some nissan exhaust gaskets, any better one?
Old 06-02-2008, 16:31
how much running in time/miles has the engine had since the rebuild?
when i built my current engine with pistons and re-bore etc, it did smoke a little to start with whilst it bedded in. also there was some oil to be burnt off that i used to lubricate all the internal parts when re-assembling the engine.
it soon settled down and stopped smoking as the rings etc bedded in
Old 06-02-2008, 17:16
Less than 5kms
Old 06-02-2008, 20:14
might be moisture in the exhaust
Old 06-02-2008, 20:56
Why did you rebuild it?
Old 06-02-2008, 21:14
Thanks guys for your attention.
Head gasket blew after a track session.
