Old 09-04-2006, 18:10
Evarus Evarus is offline
S12oc Newbie
Evarus is an unknown quantity at this point
Default Slight problem with popups And fuel pump
ok well just got myself a nice black s12 and doing some welding to the sills atm engine needs to be changed but i have a rebuilt ca18et sitting in a friends garrage that i might put in for the time being but will eventualy have a ca18det or a sr20det in once i have saved a few coins.
Anyhow the lights go up just fine and they sometimes go down, I have changed the relay that i thought was the problem but still no luck. Just cant seem to work out whats wrong with it as it seems just random as to when it works.
Also my fuel pump is NUTS the thing just wont turn off. When i turn the ignition on the fuel pump starts and just stays on all the time and basicaly makes the engine pop and fart alot lol if anyone can tell me how to fix this i would be very happy.
Thanks
Old 09-04-2006, 18:28
if ya find the problem and need any spares mate, give me ashout, i've got loads.
Old 09-04-2006, 18:59
DriftNinja's Avatar
DriftNinja DriftNinja is offline
DriftNinja is an unknown quantity at this point
Just me again sorry remade my account and name as evarus was my old name i used before i got the s12 heh.
S13eater where abouts in the uk are you? as i might need to get some bits of you in the near future heh
[center]
Nissan Silvia S12 - CA18ET
Old 09-04-2006, 21:07
im in chesterfield, derbyshire.
Old 10-04-2006, 07:45
problem with headlight and esp them not going up and down properly is often a switch problem, if you know anyone with an s12 you could swap with to test normally is the best way to tell without the expense.
Old 16-04-2006, 16:51
Andy Andy is offline
Andy is on a distinguished road
Default Light switch
Hi
i had a sim problem with my lights ,take out the switch and on the back is a bit of plastic take it off and you'll see the contacts are like points clean them with emery paper and bend the contacts a little, thats what i did and now my lights fine.hpoe this helps.
Cheers Andy
