Old 02-08-2006, 16:08
duncan's Avatar
duncan duncan is offline
Default apexi safc
has anyone fitted one of these? if so could you tell me which wires you spliced into on the ecu please. i have it fitted in the dash now and i'm mad to get it wired up. many thanks....
Old 03-08-2006, 00:25
Back Seat Chatter!
we've got two writeups on club-s12.
http://www.club-s12.org/forums/index.php?showtopic=6468
http://www.club-s12.org/forums/index...howtopic=10604
it's for a safcII, but all the relevant information is there. you just have 1 less wire to splice compared to the SAFCII.
and just so you know...that ECU pinout is on the HARNESS side...I was looking at the connector from the ECU side, and got all the connections reversed from left to right and the damn thing didn't work..took me like two days to figure out with the help of people chatting to me and looking at the wiring diagram in the FSM
edit: also note that that pinout is for a USDM spec car..so it MAY be different, but I doubt it.
Old 03-08-2006, 07:45
turbozx turbozx is offline
im just about to wire the safc 2 in and have sused the wiring ill post it up tonight!
Old 03-08-2006, 08:43
The wiring is easy, I told Adz-S12 how to do it
Old 03-08-2006, 13:45
duncan's Avatar
nice one. thanks martin
Old 03-08-2006, 17:42
SAFC_2_Wiring colour code.doc
Hope this helps
Old 03-08-2006, 18:13
Dr silvia wired Adz safc11 up .He should be able to guide you through.
Old 12-08-2006, 11:11
does anyone know what afm no. you type in to the safc 2 for afm type
HW 04 As the write up on the us s12 club states
Or HW 07 as the manual states for a s13 ca18det silvia?
Old 13-08-2006, 19:36
fitted it today, for anyone doing this you need to take the RPM feed from near the coil BLUE wire not by the ECU as it doesnt work!
Old 26-09-2006, 22:34
honest_jim honest_jim is offline
honest_jim is an unknown quantity at this point
mine did when i fitted one to my old car?
