Old 10-10-2006, 21:00
Default hears one for 30psi
martin you seem to know your maths, so if my tyers are 4.55% bigger than the stock wheels 28mm bigger, what would the difference through gears be in mph,i can't remember what tyers i had on when i found out my clock was 6mph out.
Old 10-10-2006, 21:09
All i need to know is the tyre size
Old 11-10-2006, 05:44
Magnum's Avatar
Magnum Magnum is offline
go here http://www.miata.net/garage/tirecalc.html and imput your stock tire size then the size you are using now and it will tell you the difference.
Old 11-10-2006, 07:51
235/45/17's martin, cheers.
Old 11-10-2006, 15:19
You will travel 4.6% faster.
Which to be honest won't make a huge difference. The speedo's over read anyway, so this will make it more accurate
Old 12-10-2006, 07:22
Magnum's Avatar
When your speedo reads 60mph your actually doing 61.6mph.
Old 12-10-2006, 09:32
No, this is wrong. For starters on a standard treaded S12 when the speedo shows 60mph, you are doing about 52-53mph.
With oversize tyres, you probably are only doing 56-57mph most.
Thats why when you try to drive per the speedo at 30mph it feels so damn slow, because its only about 25mph.
