Old 31-10-2006, 01:07
smoker's Avatar
smoker smoker is offline
Default Play in rear wheel bearings
Hello all, I'm getting my car Mot's next week and I found a little play in the rear wheel bearings when i rocked the road wheels. Does anyone know if this is acceptable or do I need new bearings....looks like a big job . I didn't hear any bearing noise out on the road.Thanks
Old 31-10-2006, 09:25
there shouldnt be any play really,its a quite a job doing them involving taking the arm off ,undoing a bit nut that is done up somewhere around 215 lbs ft or more,and pressing the old bearing out and pressing new one in,you need a bench and large vice if your gonna do it otherwise i would give it to a garage to do if they need doing
Old 31-10-2006, 13:48
smoker's Avatar
Thanks for reply it's not looking good, has anyone here had their car pass an mot with slight play in rear wheel bearings ?? Does the FSM mention any allowance for play ?? cheers
Old 31-10-2006, 14:08
drop the drive shaft off the wheel end, then borrow a talk wrench and set at 289ft/lb, then see if the nut that is inside will tighten anymore.the shaft has 6 x 12,, bolts.
Old 31-10-2006, 20:28
a very slight movement may get through. Just give it a go at a friendly Mot station. They may not need replacing, just need repacking and nipping up slightly
Old 01-11-2006, 00:16
smoker's Avatar
Thanks for that i'll try giving the nut a tweak sounds alot less hassle than dropping the suspension arms etc.
