Old 18-10-2006, 22:10
henrix's Avatar
henrix henrix is offline
henrix is an unknown quantity at this point
Default White Instruments
anybody have white instruments in theyr S 12? or have a layout file on the computer?
I want White instruments
I'm sure someone else does too:P
Nissan Silvia S12 1985
FJ20E 2.0l 16v. DOCH
Old 19-10-2006, 05:43
Dr Silvia's Avatar
not come across any white dials yet just badly made aluminium dial surrounds i will have a look at the possibilities later this morning
Old 19-10-2006, 20:38
henrix's Avatar
okey! thnx alot!
Old 21-10-2006, 02:20
Dr Silvia's Avatar
ok gotta admit i forgot all about this till an hour or so ago
anyhow i've stripped a dash unit apart and got the dials out
the guages for boost/fuel and oil/water are simply two thin sheets of acrylic
however the speedo and tacho dial faces appear to be printed acrylic..
this means that witha rub down with fine wet n dry will leave you witha clear plastic plate which you can then have re-printed. The warning lamps are coloured by removable sheets of couloured acrylic.
im going to try an find someone who can print these up as im interested now i've got it all apart i think a signwriter will do the job.. fingers crossed...
Old 21-10-2006, 02:24
adzs12's Avatar
adzs12 adzs12 is offline
Forum Regular
Nice job hope they can do it
Old 21-10-2006, 08:11
i'd be interested in a set ant.
