Old 15-09-2006, 11:11
Default s12 coilovers
orderd my coilovers from rally design yesterday and got them this morning
Old 15-09-2006, 11:29
Shaun
You're gonna have a problem there mate. The thread tubes aren't long enough.
ie, you won't be able to lower it enough.
You will have to make sure you weld the tube on lower down on the strut
Old 15-09-2006, 11:39
thats the only ones they had, they are 6 inch and the springs are 9 inch, what where the lengths of yours again ?
Old 15-09-2006, 11:54
I think the threaded tubes are 9"
Best just to put the tube a bit lower on the strut.
Won't be a problem though
Old 15-09-2006, 12:02
ok martin, but i've just measured the standard springs and they are 9 inch as well, if the threaded tubes are welded onto the very top, they still go 4 inch past where the standard spring sits.
Old 15-09-2006, 12:04
Yeh but bear in mind that the new springs are stiffer and won't compress as much.
You might be ok, but just be careful.
It won't harm you to do put the tubes lower down, you'd never use the top bit anyway
Old 01-12-2006, 13:37
Old 01-12-2006, 13:39
just a pic and update of the finished items.
Old 01-12-2006, 18:18
They look superb mate, how much they set you back?
Old 01-12-2006, 18:47
£160 with vat and postage for the teins, £100 for both coilover kits and i've put new kyb's in
