Old 29-12-2006, 18:28
smoker's Avatar
smoker smoker is offline
Default Missfiring
Hi Hope your all having a good Christmas , I took the Silvia for a run on Christmas eve and it started missfiring badly at about 3000 rpm under heavy acceleration. It will run perfect all day until i press the accelerator and get the boost pressure up then i have to back off the throttle to stop the missfire.
Took a look at it today and the intercooler pipework looks ok and I swapped the AFM over too which made no difference. If I return boost pressure to standard 9 psi the missfire goes away... . If i increase the fuel rail pressure to 40 psi the missfire nearly goes away but still coughs a bit at 4000 rpm and doesn't have as much power as it did . Somethings gone wrong it was running perfectly and i'm out of ideas. Any help appreciated
Old 29-12-2006, 22:58
Sounds like you need new spark plugs. Ive had the exact same problem. get some bcpr7es plugs and space them to 0.9mm.
Old 29-12-2006, 23:05
pop off valve coming on boost leak ?
Old 30-12-2006, 00:57
smoker's Avatar
Thanks for replies . My plugs are BCPR7E's gapped to 0.9mm...they have only done about 3k miles but I will change them anyway. The pop off valve is plugged and I can't see any other obvious boost leaks
All i can think off is the intercooler is leaking when it gets pressurised but it looks ok. Could the fuel pump be not supplying enough fuel ?
Old 30-12-2006, 01:18
could be or fuel reg is stuck, to much pressure or not enough maybe
you can check for boost leaks with a gas blow lamp. have the car running turn on the gas (don't light it) blow the gas on to and around anything that may be a boost leak. the revs will pick up if the gas is sucked in through a leak
check inside the dizzy cap
Old 30-12-2006, 01:30
Thats a good tip that is
