Old 25-01-2007, 22:22
Default headbolts
has anyone found a reasonably priced supplier for ET headbolts? nissan is nearly £50, found them for $46 plus shipping but probably get stung for import too. anything in the uk?
Old 26-01-2007, 02:03
Whats wrong with £46 from nissan
Old 26-01-2007, 03:34
i don't know but i've got to buy some more engine mounts, to put the fj in, i think i've done my self wrong gettin rid off my old ones ,as i have to buy the same ones again, and never got payed for the last ones .
Old 26-01-2007, 09:52
which mounts shaun,the metal brackets or actual rubbers?i bet they are totally different to et ones as well?i could of dug some out for ya otherwise
Old 26-01-2007, 10:18
s12Rob's Avatar
s12Rob s12Rob is offline
you dont need to change the head bolts, they are not stretch bolts.
Old 26-01-2007, 10:19
If they have been used in the past and some monkey has over tightened them beyond there yield, then the only safe way is to use new ones.
Old 26-01-2007, 10:27
naah mike its the actual rubber ones, i've got some std s12 ca ones, the fj ones are just a block of rubber, with threaded bar each side, i do have some spares somewhere, but i can't seem to find them yet.
Old 26-01-2007, 13:02
what's that got to do with headbolts?
Old 26-01-2007, 12:59
compared to £11 for DET bolts, it's a complete rip off
the reason I want new is because the bolts I took out are 22 years old and I don't trust them, I don't fancy re-sizing the threads in the block either, I've already got the crank in and prepped the bores. I might spec some 12.9 high tensile bolts myself, can't cost more than £15 like that I recon
Old 26-01-2007, 13:00
Whats standard 11.1?
