Old 10-03-2007, 07:50
James H's Avatar
James H James H is offline
Default Rigid engine mounts?
Has anyone got a set on there s12maybe of another Nissan or even made there own, would love to get a set of rigid engine mounts as my engine cradles so much under load (even whilst revving you can see loads of movement)?
thanks James
Old 10-03-2007, 08:08
Rigid engine mounts are going to make it damm noisey in the car! Plus I can't imagine thats going to do an unbalenced engine much good. I heard somthing about draining the silicone out of the standard Rubber ones and then refilling it with Polyeurathane. Might be a better option.
Anyone?
Old 10-03-2007, 09:31
thanks James
i have heavy duty mounts,pm if interested
Old 10-03-2007, 09:58
I have solid mounts aswell, if im correct they are just ford transit solid mounts
Old 10-03-2007, 11:33
James H's Avatar
Oh cool how do you find them Adz? Any idea what Transit year/model they came off?
Old 10-03-2007, 11:41
£15 from rally design 40mm ones, ask for uprated rs2000 mounts, then you need to make a oblong plate with 3 holes in, they where mine.
Old 10-03-2007, 14:29
James H's Avatar
Cheers dude don't sound too hard can you get away with raising the engine slightly & fitting them or do you have to remove the engine, also how did they perform & don't spouse you or Adz have any pic's pf the plate required?
thanks James
