Old 30-06-2007, 19:47
Beany-s12's Avatar
Default new wheels!
bought some wheels today that were advertised as 17x7s! didn't bother checkin them as was half asleep but got them home and had a look and it turns out they're 17x8s(super advans)! not sure wot offset but they r 4 stud and came off an r33 skyline! does any1 know if i'm gonna have problems with rubbing and best tyre size? i was thinkin 225/40/17!
Old 30-06-2007, 21:04
you need to know the offset to tell if you are going to have problems with rubbing.
215/40/17 toyo proxes would be a good choice
Old 01-07-2007, 02:18
You could go wider than 215's on 8" rims. As above though the offset will determine a lot, although I'd wager that they'd be ok coming off an R33.
Are you about at work Tuesday afternoon? Might come up and get the front pipe after I land at Gatwick.
Old 01-07-2007, 09:00
Beany-s12's Avatar
yeah i should be at work til bout half 6 tuesday! i'll pm u the address and post code!
Old 01-07-2007, 10:54
Yes he can go wider than 215 wide but from experience It makes the drive boring,road feedback is numbed down and the steering is heavy and suffers alot from tramlining.
Getting a decent brand and compound of tyre is twice as important as the tread width
Old 01-07-2007, 16:22
Beany-s12's Avatar
they've got 235's on then at mo and just thought a 215 might look a bit stetched on an 8" rim and a 235 is more likely to rub! just had a look and think the offset is 32!
