Old 23-07-2007, 17:50
Default My windscreen lifts when I close the door???
Erm as it says, when I close the door the lower drivers side of my windscreen can be seen lifting from the dash, just slightly. It also does it if I push
I have checked the bit of plastic at the bottom and the screws are tight even if that doesnt appear to hold the windscreen in.
Are these glued in? has my glue died? Do I need to get this fixed ASAP? (glass cover on insurance anyone seeing as it got a chip/small crack in it going to JAE)
Worried its going to fall out , and you just know it will happen when its pissing it down
Old 23-07-2007, 19:15
smoker's Avatar
smoker smoker is offline
My windsreen makes a kind of tapping noise if i drive the car over 80 or so ..i presume the adhesive holding it in has dried out and it's loose
Old 23-07-2007, 19:29
sounds like you should make use of your windscreen cover
Old 23-07-2007, 20:25
Windscreen cover? is that the bit of plastic at the bottom of the screen where the wipers are, its as tight as it goes
Old 23-07-2007, 20:51
no its what you normally get free with fully comp insurance
yep your sealants gone dry and broken up i recon
Old 23-07-2007, 21:26
s12Rob's Avatar
s12Rob s12Rob is offline
or you could follow your local bin lorry, follow it, get road name, time, reg number and the company name, ring in and say something flew out of it onto my car and damaged it, hey presto, free windscreen
