Old 14-08-2007, 10:08
badboy's Avatar
badboy badboy is offline
Default exhaust
hi there could anyone tell me if s12 and s13 down pipes are the same
Old 14-08-2007, 10:20
IIRC they have a slightly different bolt pattern between the T2 and T25
Old 14-08-2007, 10:21
badboy's Avatar
if the diameter is the same could i not use my flange
Old 14-08-2007, 10:22
Turbo end or exhaust end?
Old 14-08-2007, 10:23
badboy's Avatar
turbo end, basicaly i would like to fit a larger bore down pipe
Old 14-08-2007, 10:37
If you mean swapping the T2 flange onto a T25 S13 downpipe then wouldn't it be easier to just go for the T25 conversion and possibly even buy a buy a SS downpipe?
I can't see it causing any problems so long as you're handy with a welder. I didn't think that there was that much difference between the two though?
Old 14-08-2007, 10:55
badboy's Avatar
dont realy want to convert to t25 just a bigger bore, might have to knock something up myself just wondered if there was an easy way round it, ta for the advice anyway
