Old 11-09-2007, 08:44
j.blund j.blund is offline
S12oc Newbie
j.blund is an unknown quantity at this point
Default ca18de to ca18det
i have bought a ca18de engine with loom and all to it i have also ordered
ca18det pistons, rods, injectors, girdle, flywheel, piston squirters, and ecu.
injector resistor.
do i need something else??
will i bee able to wire the injector resistor box to the n/a loom pointers tips and hints please.
regards/jocke
Old 11-09-2007, 10:04
Why not just buy a CA18DET?
The loom is different in certain places. You will also need to drill and tap the block for the turbo oil feed, and also use the DET sump for the oil return
Old 11-09-2007, 14:07
S12oc Newbie
ye i have a det oil pan and for drilling the block no you are wrong the oil feed is just plugged with a tread bolt.
i now that i have to wire the loom diffrent but i have a guy to sell me a loom from a det. hmm i will def try to wire the remaining wires.
the reason for this is that there a re tons of Cheap det internals in sweden. and i got the ca18de enngine complete with all for 1000 swedish kronor and the rest (det stuff) for 2500 kronor total of 3500 kr equal to 259 £ and is that cheap or not ???????
another thing i realised when disasemblig the intake it is a butterfly valve type ?? good or bad?? i have a det intake to use but wich one is better??
regards/jocke
Old 11-09-2007, 14:18
Ahh thats handy, Nissan did a bit of thinking with the oil drain.
I guess it doesn't make much difference if you are rebuilding the engine. Use the DET inlet, the butterfly thing is to help the emissions and driveability.
