Old 30-10-2007, 13:31
Dazz Dazz is offline
Default Braided oil line.
where can i get a braided oil line for the turbo,?
Old 30-10-2007, 16:43
doski's Avatar
doski doski is offline
hose solutions can make up custom braided lines and are cheeper than buying goodridge ones i have had braided brake lines, turbo oil line and turbo water lines and a braided line for the oil pressure senser from them so far and they are all good
Old 30-10-2007, 16:58
if its an early engine (feed from inlet side of block) you'll need to get a custom one made up. if its a late engine (feed from turbo side of the block) just use an s13 one
Old 30-10-2007, 18:14
You'd be best to use the S13 piece that goes in the block too if you want to use an S13 line as you will find it rather tight otherwise.
Old 30-10-2007, 23:48
veyr true, thought of that while i was out after i posted
Old 31-10-2007, 11:16
Thanks guys. But whats ther bit i need for the fit?
