Old 07-12-2007, 17:23
Oscar's Avatar
Oscar Oscar is offline
Default ae86 rims
ive noticed a lot of ae86 rims forsale on drift works, noticed that they are 4 stud..... any chance they will fit? im looking a difrent rims at the mo, and looking at old school type rims and just wondering wat will fit........ obviously 4x114, but just wonderd if anyone had used any other in the past like toyota rims?
Old 08-12-2007, 16:01
Oscar's Avatar
bump
Old 08-12-2007, 16:45
Oscar's Avatar
someone must know!!!!!!!!!!!
Old 09-12-2007, 22:43
blitz blitz is offline
AE86 will fit. it's the same 4x114.3, so is datsuns 280zx. 15x7 +0 can be fitted without spacer. need 195/50. 195/60 on 15x7 is a bit too tall, and it rubs occasionally on deep potholes + big bumps.
you can go wider than 7 inch, just have to watch the offset and use 50 aspect ratio tires.
I have 15x6.5 +35 with 195/60, and there is very little room between the tires and strut towers in the front. maybe like 2-3 mm, but it's not rubbing at all.
Old 10-12-2007, 19:30
Dazz Dazz is offline
Nice info there, im always out to swap rims.
Old 11-12-2007, 11:47
i use 225/45/17's on the front and 235's on the rear, they do touch slightly onto the spring platform, but grinding a little square hole sortes that out.
