Old 07-08-2006, 13:39
duncan's Avatar
duncan duncan is offline
Default s13 inlet mod
is anyone willing to modify an s13 inlet to fit the s12? i have both complete plenums but no one will touch it over here and i dont have the gear to do it myself . i know 30psi has this done and rich was on about doing it.
Old 07-08-2006, 16:28
Heres some pics of mine if it helps at all:
Someone else has done it:
Old 30-09-2006, 00:31
toytoy's Avatar
toytoy toytoy is offline
toytoy is an unknown quantity at this point
Question
Hi !
The ca18 run better with this inlet or not ?
Thanks
www.clubS12france.com
Old 06-12-2007, 10:21
mr_turbo's Avatar
mr_turbo mr_turbo is offline
have you got any more detailed pictures of the welding you done to get this to fit?
ive had a look and it looks like a massive amount of welding to get it to fit?
Old 06-12-2007, 15:32
Some more pics. But I didn't weld it so can't truly say how difficult it is. Probably better to make one from scratch.
Old 06-12-2007, 15:43
mr_turbo's Avatar
cheers for the extra pics!!!
looks like a realli fiderly job im tryin to weigh up if its worth it coz obv the size of the inlet port is still the same as standard and obv dont wana create a huge swirl as the gases are forced into the head!!
im either going too make it fit or play around witht the oringal put the s13 throttle body on and open up the inlet to take the larger body and make up a new rail with the s13 injectors on!
did it feel any diference to drive ie response?
