Old 02-03-2008, 18:10
s12andy_s_ s12andy_s_ is offline
S12oc Newbie
s12andy_s_ is an unknown quantity at this point
Default Dash dials inop
well drove the s12 yesterday and everything working, took seats out today to do some work to it and started it up to get a bit of heat, so working away i looked at the dash and nowt was working, no oil press, temp or rev's? gave it a rev no difference, only thing that seems to be working is the petrol dial. also the battery light is staying on but belts are fine. you think it could be a fuse/wiring from taking the seats out??
Old 04-03-2008, 19:45
S12oc Newbie
well thanks for all the interest but there done
Old 04-03-2008, 19:52
i had a problem with some of the guages and it turned out to be a fuse.
Old 08-03-2008, 17:09
zxocmars zxocmars is offline
What was wrong Andy, and how did you fix it?
Might come in handy if anyone else has a similar problem
Old 08-03-2008, 13:36
Smile dash probs
Check the fusible links by the batter under the black lid.
I had this problem with my MK1 and the wire had corroded by the connector.
Hope this helps.
