Old 05-03-2008, 18:21
Default What type of oil in dampers?
Hi guys,
As some of you know I am in the process of converting a standard set of suspension legs into coilovers. I have got stuck & need help with identitying the type of oil that I need to put in the leg? what viscosity to use? I am sure this is crucial to the performance of the damper.
Any help is greatly apreciated.
Many thanks,
Hans.
Old 05-03-2008, 18:31
i'am sure the silvia god puts auto transmission in his to uprate them, i could be wrong though.
Old 05-03-2008, 19:02
that he does
Old 05-03-2008, 19:33
ste00 ste00 is offline
ste00 is on a distinguished road
yeah transmision fluid is good, thicker the oil the harder the damper will be
Old 06-03-2008, 07:00
What about 5WT oil for motorbike forks? readily available I think.
Thanks for your help guys.
Hans.
Old 06-03-2008, 07:04
How hard do you want it, I did the last silvia with gearbox oil and it was hard.
You can also overfill slightly to get them harder still.
Off the top of my head I think it's 280ml of fluid you need to put in.
Old 07-03-2008, 07:59
Ronin's Avatar
Ronin Ronin is offline
Silvia Driver
Would that be the dampers on my car Dave?
If so anything you neglected to tell that you've done?
Old 08-03-2008, 17:26
I used extra heavy motorbike fork oil in the end at £7.20 +vat for 1 litre(which is all you need). Also, yes you need to fill both the inner and outer tubes equally to about an inch from the top or you can't get the tops to screw back in. They are rock hard now and just the tyre seems to give.
The car should step out big time now!!!..... AWESOME!!!!
Many thanks for your advice guys.
Cheers, Hans.
Old 10-03-2008, 09:16
Yes, Dom I think they were still on the car when I sold it.
Whats happened have they fallen apart or something?
Old 10-03-2008, 15:40
Ronin's Avatar
Silvia Driver
No Dave the dampers are ok, the engines not to healthy as it won't start at the moment, just wondered what else you had done to it as you didn't tell me about the adjustable actuator or that you had blanked off the pop off valve, not that I'm complaining, but I don't want to do something to find you've already done it!
