Old 31-07-2008, 10:10
paulsilv's Avatar
paulsilv paulsilv is offline
Default Steering Column Adjustment
Does the steering column on a 1988 silvia adjust up and down.
Mine seems just slightly too low for me. I have a handle which was in the glovebox when I bought the car I'm unsure how to fit it, I had a quick go but it looks like a very involved job.
I have looked in the service manual, but the diagrams don't really say a lot.
Has anyone any info on this or know a way to get the handle back in.????????????????????
Old 31-07-2008, 10:30
Sharas's Avatar
Sharas Sharas is offline
Should be straight forward and simple, unless somethings broken . Ill try and get a couple of pic's in evening how it looks in my car, hope that will help you.
Old 01-08-2008, 21:10
paulsilv's Avatar
Thanks Sharas,
I'm usually quite handy a figuring things out but this looks like a dashboard unscrewing event which I'm not inclined to do.
Old 03-08-2008, 17:44
mine dont have the adjustment, but to get to where is should be you only need to take off the column couling, tis 3/4 screws under the column, and then once the bottom is off you should be able to get access to the adjustment part.
Old 03-08-2008, 23:29
UK spec cars didn't get adjustment US and JAP cars did
The only Silvia i have seen with steering adjustment is Silviagods car
Old 03-08-2008, 23:31
Dr Silvia's Avatar
ok the first thing you'll be wanting to do is take the column trim off to inspect the column itself; its no good having a lever if the shaft itself wont move!
Haven't got the manual to hand but theres one joint in the adjustable shaft shave a feel about for it! Not yet seen a uk silvia with an adjustable column though..
You take the column trim off with a long philips drivertheres 3-4 screws on the underside.
wdit: forums should lock if someone is already postinga reply!
Old 03-08-2008, 23:39
ChEsTeR ChEsTeR is offline
All european LHD silvia i have seen had a steereing colum adjustment
