Old 18-02-2006, 15:39
S12OC
Guest
Posts: n/a
Default s12 Tightening Torque
ITEM n.M
FOR CA18ET & CA20E ENGINES
ENGINE FRONT SIDE:
Alternator adjuster lock bolt 12-21
Belt tensioner bolt 15-20
Crank pulley damper bolt 123-132
Crank pulley to damper bolt 12-14
Front cover bolt 3-5
Water pump securing bolts 16-20
ENGINE RIGHT SIDE:
Air regulator 5-6
Alternator bracket 41-59
Collector to intake manifold 18-22
E.g.r valve 18-23
Fuel injector bolts 2.5-3.2
Intake manifold bolts and nuts 20-25
I.a.a unit 6.4-8.3
Oil cooler connector 29-39
P.c.v valve 29-39
Throtle chamber 18-22
Water outlet 18-22
ENGINE LEFT SIDE:
Air conditioner compressor bracket 69-78
Distributor support bolt 5-6
Exhaust manifold to exhaust tube 26-36
Exhaust manifold nuts 20-29
Exhaust outlet to turbo 22-29
Exhaust gas sensor 40-50
Heat shield plate 4-5
ENGINE TOP SIDE:
Camshaft sprocket bolt 78-98
Cylinder head bolts (1) Tighten all bolts to 29
(2) Tighten all bolts to 78
(3) Loosen all bolts completely
(4) Tighten all bolts to 29
(5) Tighten all bolts to 74-83
Rocker shaft 18-22
Rocker arm nut 18-22
Rocker cover 1-3
Spark plug 20-29
ENGINE BOTTOM SIDE:
Connecting rod cap 32-36
Main bearing cap 44-54
Oil pump 12-16
Oil strainer 10-14
Sump bolts 5-7
Sump plug 29-39
ENGINE REAR SIDE:
Camshaft locate plate 78-88
Clutch cover (M/T) 18-22
Drive plate (A/T) 98-108
E.g.r passage bolt 6.4-8.3
Flywheel (M/T) 98-108
Rear oil seal retainer 4-6
Starter motor 29-39
FRONT ENGINE MOUNTING
Mount to body (nut) 68-87
Mount to stay (nut) 23-27
(bolt) 19-24
Stay to engine (bolt) 31-42
Rear engine mounting,
Bracket to body (bolt) 36-47
[ Mount to bracket (nut) 41-52
A/T [ Mount to transmission (bolt) 31-42
[ Bracket to sub-bracket 41-52
M/T [ Mount to sub-bracket 23-27
[ Mount to transmission 23-27
FOR FJ ENGINE#
ENGINE OUTER PARTS:
Alternator bracker bolt
Cylinder block 43-58
Front cover 30-40
Alternator to adjusting bar bolt 16-21
Clutch cover fixing bolts 16-21
Engine mounting bracket
to cylinder block 30-40
Intake manifold nuts 31-42
Intake manifold support bolt 30-40
Exhaust manifold nut 16-21
Throttle chamber bolt 16-21
Water pump bolts
M6 6.3-8.3
M8 16-21
Cooling fan bolts 6.3-8.3
Spark plug 20-29
Compressor bracket bolt 30-40
Compressor to bracket 43-58
Crank pulley bolt 147-196
Distributor support bolt 6.3-8.3
Water outlet bolt 9.1-11.8
ENGINE INTERNAL PARTS:
Camshaft bracket nut 14-18
Camshaft sprocket bolt 108-137
Cylinder head
(1) 49-59
(2) 118-127
Main bearing cap bolt 83-98
Connecting rod nut 59-64
Jack shaft locating plate bolt 6.3-8.3
Jack shaft sprocket bolt 76-98
Chain guide bolt 16-21
Chain tensioner bolt 6.3-8.3
Front cover bolt
(M6) 6.3-8.3
(M8) 16-21
Rear oil seal retainer bolt 3.7-5.0
Oil strainer bolt 16-21
Sump bolts 7-8
Sump plug bolt 35-47
Flywheel bolt 137-157
