Old 11-02-2009, 17:41
WM-S12's Avatar
WM-S12 WM-S12 is offline
Default S12 mot
My MOT runs out on the 18th, booked it in for the 13th this week.
Can someone enlighten me on alittle curiousity i've got bugging me at the moment, I took out my BRIDE seat and swapped it back to the stock drivers seat, however I'm still using a road legal 4-point harness with the stock seat. ( read in the harness manaul that its legal aslongs as the harness straps sit inbetween the headrests. )
I'm just curious as i've only got two seats in the car, the backs completely stripped, minus all the rear belts to, left rear, middle and right rear. Will the MOT tester instantly fail it seeing as they've been removed or will he just go alright, he made my job easier only have to check the front two? I'm skeptical and begining to think it's going to be a spectactular fail and come the 18th my s12 will be off the road....
If anyone can clear this up with me I'd appreciate it, Cheers.
Old 11-02-2009, 20:27
I'm almost sure it will be OK if the you have taken both the seats and the belts out together and not left one without the other. Only problem you might have is that on the V5 and the vosa records your car will be shown as a 5 seater
Old 11-02-2009, 22:08
lincolnlad lincolnlad is offline
lincolnlad is an unknown quantity at this point
it will be fine if the seats and belts have been totally removed they cant be tested for or failed on if they are not their, only know this as mine is stripped out in the rear.
Old 11-02-2009, 22:32
WM-S12's Avatar
Well I could always fill in the "changed details" part on the V5 before it goes into the MOT, then send it away after, least that way they know I intended to update the details.
Actually looking at my V5 it does not state the number of seats in the "number of seats, including driver" section
Also checked on the vosa website, MOT check and it doesn't come up with anything regarding number of seats, I'll still change it anyway just so it is registered with them.
Old 11-02-2009, 22:59
Leave the seats as it is. You don't want the DVLA thinking you've radically changed the chassis and go all SVA on your arse.
Old 12-02-2009, 08:59
I agree with 30psi.
I've had a number of cars pass MOT's no problem without rear seat belts if the rear seats aren't there. Don't worry about it.
Old 12-02-2009, 14:51
paulsilv's Avatar
paulsilv paulsilv is offline
I agree with Lincolnlad, I was told a few years ago that if I left my bald tyred spae wheel in the car they would fail it, if I took it out they would have nothing to fail.
On a side note, my everyday car was due for mot and insurance at the start of Feb, i insured with Kwikfit (the cheapest I found) and got a free MOT as well. I booked it in and they failed it on the rear discs and pads, then quoted me £263.
I had got a quote the day before as I knew they were ready for £55 from the local factors.
I immediately took it half a mile down the road to a place that do loads of trade mots every day and after paying £40 within an hr I had a new MOT.
a lot of this MOT stuff is rubbish and it is in the opinion of the tester to pass or fail, not wishing to dismiss safety here but you get my drift.
