Old 21-01-2007, 17:39
RichardK's Avatar
RichardK RichardK is offline
Forum Administrator
Default Front Brakes
I now need to look at my front brakes. Thery need uprating considerably.
I want bigger discs ideally and 4 pot calipers.
What's the best way to achieve this?
I was looking at the brakes on a skyline today, they looked ideal. The owner suggested they may well fit.
Old 21-01-2007, 17:47
groove your front discs or buy grooved ones and mintex or porterfield pads and then bleed the brakes right though with some decent brake fluid, and get some nice sticky rubber on those wheels and they will be the bollocks. I can lock mine in the dry at 100 ish with toyo tyres. I find my brakes to be prefectly adaquate for a 'fast road setup'
there are other options, use the forum search option
Old 22-01-2007, 09:58
RichardK's Avatar
Forum Administrator
Definitely want to go for 4 pots. Bigger discs would be good too...
Are S14 and Skyline calipers the same?
Old 22-01-2007, 11:09
Locking brqkes up at 100mph is achievable with any brakes. What you want is a set of brakes that can slow you down from 100 in control without losing efficiency ie brake fade.
Try braking from 100mph down to 30, then try it again and you will notice on the 2nd or 3rd attempt they'll fade.
Even if you have really good pads the 22mm discs will heat up real fast, and brake fade is inevitable.
The 4pots will help with the heat issues but at the end of the day the disc will be the first to cop out.
Oh and the skyline discs won't fit.
Old 22-01-2007, 12:14
RichardK's Avatar
Forum Administrator
Thanks for that Martin.
So what options do I have as far as upgrading the discs?
I'm now thinking S14a calipers. So need to work out the disc side of it now.
Old 22-01-2007, 12:21
Skyline calipers are for bigger discs, so the offset will be wrong. These discs will work nicely with them though:
http://www.datsport.com/R32Z_CO_DS.html
That is the only true upgrade.
S14/Z32 calipers are designed for 280mm discs so bolt on with no issues. You dont actually need spacers for the thinner discs either.
Other than that, you could go for custom bells/discs that are available for the S13 but the offset of the bell might be wrong, so some measurements of the disc offset will need to be made. You never know, they may be the same.
Old 22-01-2007, 20:01
Originally Posted by 30psi
Locking brqkes up at 100mph is achievable with any brakes...............
Martin you seem to take any oportunity to pick at whatever i say, i should not have to cover every angle of a statment i make just to stop you from picking at it like a magpie in a cornfield.
I never had that much bite on my standard discs and pads compared to how they are now It is a seriously vast improvment on the standard setup and i was reccommending it as it is a decent,easier and cheaper option.I never suffer brake fade from 'fast road' type driving.I only got bad brake fade at Rockinham after doing 120 down to 20 over and over again after about 15 minutes because of some daft chicanes they put up on the oval track.
I didnt find s14 front calipers on std s12 discs to any better whatsover than the setup i use Richard, If you are going to go for 4 pots you definatly need different discs
Old 22-01-2007, 20:13
RichardK's Avatar
Forum Administrator
Yep going for the S13 setup by looks of it. Got some S14a calipers. Just got to work out what else I need...
Old 23-01-2007, 10:42
Not 'picking', but you seem to forget I've used the same pads as you, and yes they were better, but locking brakes up isn't a performance indicator. Just because brakes are grabby doesn't mean there going to be good for continued use.
RichardK asked for brake options and opinions, which I gave him, from my own experience. Don't see what the problem is.
Originally Posted by RichardK
Martin, what EXACTLY do I need to get to do this?
Give me a ring
