Old 17-11-2009, 23:45
martin.herwitson's Avatar
Default 30 spline diff shafts
Anyone come across a nissan with R200 diff with 30 splines? I've got output stubs with the 3x2 bolt set up but this adds 30mm to the shaft length, if I can find a 30 spline output shaft straight into a cv joint I can avoid a cut'n shut driveshaft?.....don't know if nissan made such a thing....do you?
