Old 08-02-2010, 23:09
Default your opinion?
i got the below email from an old s12 customer of mine. he was asking into engine swaps and i suggested the rb or det. he then replied with this.
i will keep these items in my silvia folder, thanks.
i went down here: http://www.mikestewartperformanceengineering.20m.com/
he fiddled with the leads for the loom and the cylinder went, then he poked the injection plugs and it was the one at the front. they look very worn and split, he said it looks like the engines been taken apart alot and that's probably why they've worn. so he's going to repair them for me.
he said not to think about the RB20 or S13, the RB20 would be too heavy and the S13 engines big ends go and other problems come with them. he said the engine i have is bomb-proof and i should just get a supercharger instead of a turbo. i found this idea interesting, as i dont think the car needs anymore than 250/260bhp.
you should check out his datsun 260z - 340bhp monster.
he also has a one owner bluebird zx turbo hatch sitting there with a bit of rust. it has my engine there and its only been driven by his stepdad and he once put a bleed valve on it. he would be willing to sell it. im thinking about it for the engine, but i dont have alot of space.
thanks for your time!
david
made me laugh a little
Old 08-02-2010, 23:34
irish s12's Avatar
Jeesus,why didn't I think to get a supercharger instead of my det.It would have made so much more sense.
Old 09-02-2010, 08:12
Draconis's Avatar
Draconis Draconis is offline
The RB is not too heavy. I have done this with my person RB20. Yes it is heavier, but I had the SE/V6 model and it wasnt that much. I can give advice as to if one is to do this, what mods they should do at the minimum to ensure all is well. If you are worried about weight and such, I suggest CA18DET personally.
Old 09-02-2010, 11:17
a little bit of knowledge is a dangerous thing eh? common web 'knowledge' DETs with 'chocolate' bearings, ironic as they are identical to those in the bluebird and the ET in his S12...
bet you love it when you get E-mithers like those eh Pukka? maybe you should ask this Mike Stewart fella how to prep a classic Lotus F1 car or Chevron B16? he sounds like hes an 'expert', bound to know everything....
Old 09-02-2010, 21:43
I replied when the email arrived and said pretty much what you guys have also stated. S12s came with the v6 weighing far more. The RB engine actually isnt that heavy. And i mentioned Japsters det as an example of a high powered det that has had no bigend bearing issue.. Its poor servicing and old age that are a cause for det failure. These engines are 20 years old and people are trying to tune them with bolt on mods without rebuilding them.Ive never had bigend bearings go on any of my dets'
Old 09-02-2010, 23:30
irish s12's Avatar
It depends on how you treat them and what oil you use as well.A couple of well placed baffle plates will completely remove oil surge from the engine.
The ca18det was never any good if run on crappy 10w40 either,Mobil 15w50 will make it last a lot longer.
Anyway,there is more Nissan knowledge your little toe than in that tools whole body.If your man wants a proper job done then he will give it to you and not to mr classic car with his sheepercharger,or sorry I meant supercharger.
Old 10-02-2010, 00:30
Thanks, but im not after any more project work anyway at the moment to be honest. Completely over run with them all and getting a back log
Im really looking forward to this det 120y building next week. But i have 3 other projects to do first.....
Im also on the look out for a new daily driver for myself. Considering a Pulsar atm as there about 2600 for one on coilovers with 6pot brakes etc. Just sold my lancia delta hf turbo and breaking my rs turbo escort as its been declared cat b from a bus driving into it.
Only the wing and bumper needed replacing but its cat b due to new 'government scrappage scheme legislation' apparently.
Old 10-02-2010, 01:03
irish s12's Avatar
Buy an s12 you know you want to.
Old 10-02-2010, 11:31
ive enquired on the black FJ on zxoc but its alot of wonga for a car with no Tuuuuuuuurbo. Im considering it. But if i get it i dont know quite what i would do with it. I need at least 300hp without it being a mammoth money pit project.
Old 10-02-2010, 11:45
set of wiseco forgies, t34 and some sort of managment and you would piss over 300bhp.
