Old 08-05-2010, 03:00
Super Ace-K's Avatar
Default Won't start sometimes...
Recently in the S12, I turn the key and it won't start. All I get is a click and that's all. Seems to be if I let it idle back to normal before switching off the engine it works okay or if I just switch off engine then don't come back for a while it works. But for example, tonight I went to get petrol then when I filled up and got back into the car it wouldn't start for about 10-15 mins of trying, then tried once more and it started up.
So I either wait for 5-10 mins before switching engine off
or
Switch it off right away and then don't come back for an hour or something.
Any one know what this is, seems stupid that I can't do something simple like get petrol or call into the shop.
Old 08-05-2010, 08:28
Sounds like its flooding. If it doesnt start straight away take out the Fuel pump fuse and turn it over for around ten seconds to clear it. Then put it back in again and try it. May need an injector cleaner in the tank or even a new fuel filter which are only a tenner. Hope this helps matey
Old 08-05-2010, 09:24
sounds like your starter motor needs replacing
Old 08-05-2010, 21:59
is it cranking over on the starter?
as above sounds like the starter motor if not.
in emergency hit the starter with a hammer and a bar lol.(free's it up)
Old 08-05-2010, 23:11
Bit of an update. It still does it sometimes but I'm not sure if this is pure coincidence or it's actually doing something but when I go from say "D" in the auto gear box and push it up into "P" while I turn the ignition it seems to start.....
Old 09-05-2010, 21:01
dont you have to be in park P to start?
Old 10-05-2010, 00:02
Yeah that's what I'm saying when it's in P just by itself all I get is a click and the fans kicking in but engine won't start. I have to like jiggle gear stick up into P through the other gears while turning key and then something catches and engine starts. Fella in work was saying maybe it's the inhibitor switch?
