Go Back   S12OC UK Forum > Main Categories > Daily Chat
Old 20-06-2010, 04:36
800horsepower 800horsepower is offline
800horsepower is an unknown quantity at this point
Default ca20e pistons?
hi guys i have just pulled the head off my 12 and have found that it has pistons to sleeve 16 valvles,why? do theses come out standard in them or what? and why do they allow 16v's for are they the same as 18det pistons, im currently in the prosses of having the head folwed and have sourced some bigger inlet valvles from a bmw and then gonna pull the block down and so on.and im not looking for any excuses of doing any 18det transfers.
Old 20-06-2010, 09:09
the Et pistons do have the four valve reliefs in the top but I remember Eddy from zxoc years ago comparing them to a DET piston. The tops were the same but the grooves etc were different
Old 20-06-2010, 09:58
hey mate yeh its a bit of a weird one just trying to work things out gonna have the pistons dished,so i was just trying to work out if theyd be good enough so cheers for that info.
aaron
Old 20-06-2010, 10:54
aaron
Old 20-06-2010, 10:58
there not really good enough for much to be honest, If your going to have machining done and fit new rings obviously then there really is no reason not to upgrade the pistons to at least a det 16v rod/piston setup. There so cheap to buy
Old 20-06-2010, 23:43
what lengths are the det there obviously shorter, but will they fit the 20?. i wanna keep it a 20 no matter what as i am all for being origanal and the laws here in aus are sh#3t! though i work for an engine builder that builds sprint cars and all sorts of things so putting this together will be fun.
Old 21-06-2010, 00:18
8V pistons have 4 reliefs in the pistons for a very simple reason. It's so they can have one single casting of piston. Otherwise they would have to cast 2 pistons to match cylinders 1&3 and 2&4.
You'll notice the cutouts on an ET and DET are completely different
