Old 29-08-2009, 19:49
Default Binary and/or ROM ECU files needed desperately
as title, as many as you can guys as quickly as possible. I know its but it might help build the first successful fully mappable ECU from a stock S12 unit.
any help greatly appreciated.
cheers Ben
Old 30-08-2009, 19:00
nedge2k nedge2k is offline
Administrator
Well, i've got three ECU's in total and i'm no stranger to this kinda thing (IT guy / Web Dev) but I've not played with ECUs. How do you dump the files? I assume (hope) some kinda modified serial cable?
Old 01-09-2009, 20:07
Hi mate,
I've got a standard manual Mk1 ecu rom dump PM me your email address and I'll send it over so you can have a look as I never got round to playing with the eproms
Cheers
Simon
Old 01-09-2009, 20:16
Administrator
how did you dump your files?
Old 01-09-2009, 20:23
i think you need the mk2 ecu, i had one with a socket ready to map.
Old 01-09-2009, 20:53
I sent him a file a few days ago, which is the std mk2 bin
Old 02-09-2009, 08:47
Default Re: Ecu files
It will be good if someone has got the time to do this.
I'm pretty sure I found some good info regarding fuel maps and timing by searching bluebird turbo as some bloke in Finland had made a chip.
Unfortunately couldn't get hold of him through various sites but is some info there if you search for it.
Cheers
Si
Old 04-09-2009, 01:21
CA18DET location file will give you everthing you need except the rev limiter which uses a different multiplier. ET bin file just has less info, there's nothing extra anywhere
