Old 22-10-2006, 10:03
ollymk1escort ollymk1escort is offline
ollymk1escort is an unknown quantity at this point
Default which dump valve noise
Which dump valve am i looking for that makes like a chirping noise. its not external wastegate by the way.
cheers
p.s would i need a t piece and what size?
Old 22-10-2006, 10:57
adzs12's Avatar
adzs12 adzs12 is offline
Forum Regular
You wont get a chirping noise via a dump valve, the chirping noise comes when the air is forced back through the turbo and sounds through the air filter. However this is mildly quiet compared to when an external wastegate is used.
Old 22-10-2006, 11:59
You technically only need a dump valve at very high boost.
I think the chatter noise sounds best
Old 22-10-2006, 12:09
yeah but i like dump valve noise as well so am gonna go for one. Hows best to fit it??
can i put a t peice between the intake and turbo just cut it and join with samco hose what size do i need??
Old 22-10-2006, 20:43
i think my dump valve pipe is 1" internal dia, so all you need is a bit of tube 1" or 25mm external dia bout 60mm long and get it welded in the pipe between the turbo and the throttle body, and then get a bit of samco or similar 1" internal bout 100mm long to connect the valve to, then the vacum pipe on mine is 'T'ed off the vac pipe that goes to the fuel pressure reg.
hope this helps.
Old 22-10-2006, 22:48
yep weld a outlet on your pipework preferably around 2 inches or so away from where it bolts to the inlet manifolds throttle body. Then the reference pipe that needs to go on top of the dump valve can connect up to a disused blanked outlet that you can find attached to the bulkhead above the hydraulic clutch fluid pot
