Old 21-11-2006, 23:20
mr2sc89 mr2sc89 is offline
mr2sc89 is an unknown quantity at this point
Default followers in a ca18det (help)
hello, does any body know that if the hydraulic followers under the cams should be spaced or set up? the follower seems to have no move ment?
the valves have been re ground, i have replaced the stem oil seals a recond the head and ported and polished it, but the valves dont seem to close properly when i turn the cam over, this is present on all valvs? i seems as if the all followers are seezed. the reason i did all this to the head was because in original condition at 3000 rpm plus there was a rattle from the inlet valve on the first cylinder? has anybody come across this before? any help is appreciated. thanks
Old 22-11-2006, 16:50
they are hydraulic, there isn't any adjustment. you should really get them cleaned out, there's a lot of crap gets built up inside them
Old 22-11-2006, 17:00
I thought we had mechanical lifters in the CA18ET? (would explain why they were solid )
Have you checked that none of the bolts that hold the rockers in have been pulled out of the head, it seems to be a common problem on the 8v?
EDIT - http://www.nissansilvia.co.uk/vbb/showthread.php?t=1032 Might help
Old 22-11-2006, 17:10
Yeah but this bloke has the DET
Old 22-11-2006, 17:16
I'm acctually a total moron!!! I can't seem read or write today, it about the 4th post I've shoved on a forum that's totally useless in the last 24hrs!! Sorry all
........does this make 5 BTW
Old 22-11-2006, 17:37
adzs12's Avatar
adzs12 adzs12 is offline
Forum Regular
Lol yes no5 gets a double trout
