Is there any company doing L.S.D.'s for the S12?
Mines a Mk2 i think (1988).... |
no but you can get a ATB from quaife
And if you don't have £600 spare for a Quaife then you can use an S13 LSD with some other bits, for very little money.
600?.....
.....Thats over double what i paid for the car - S13 it is then.If anyone who has used and S13 diff could post up some picks of it, plus extra parts i need - i would really appreciate it. Thanks |
Fully strip the S13 LSD, and removing the ring gear from it. Throw ring gear, case, shims etc in the bin Then strip the S12 diff, and rebuild it with the S13 inner diff unit. ie bolt the S12 ring gear to the S13 unit. Then the shafts need some work. You use the short S12 shaft on the driver side with the S13 inner joint/inner On the short side (passenger side) you can use the standard short shaft but you have to remachine so its like the S13 shaft. ![]() ![]()
Cant the left output shaft be used from the s13/s14 diff?
