Old 10-01-2007, 00:36
Default Standard fuel pump output guess?
Who with a standard low miler s12 wants to test the standard lph output of the fuel pump.
I was thinking that someone could undo the hose before it reaches the regulator and then extend it into a jerry can and see how many litres it pumps out in 10 minutes, then multiply it by 6 or 5 minutes by 12. Its only out of interest........ I have heard there around 120lph at a guestimate, the s13 pump i have also heard that is 95lph. Which is surprising.
Old 10-01-2007, 01:12
Hate to make things more complicated but the flow rates stated by pumps are also at a pressure (3 bar maybe) so you would have to test what it can flow whilst maintaining this pressure.
Also needs to be tested what it can flow in a boost situation ie higher pressure, which is probably where its main weakness will show up.
Just fit a walbro. Simple
Old 10-01-2007, 01:23
can we not measure the pressure the pump is putting out with a hand held fuel pressure gauge
What pressure is the walbro pushing 255lph out at?
I have got a walbro fuel pump,Im just wondering out of interest
Old 10-01-2007, 01:25
I think it may even tell us in the manual what pressure the fuel is from the pump.
Dunno do a google, but I think the Walbro can push that flow at 2 or 3 bar
Old 10-01-2007, 01:27
The service manual will tell you what effect the regulator will have on fuel pressure, but nothing about flow or absolute max pressure
Old 10-01-2007, 01:28
simpler than you think Martin, the walbro pump literally pumps out 255liters every hour, pressure doesn't change that
Old 10-01-2007, 01:42
Don't see the point of testing it like that.
There's some info here
http://www.stealth316.com/2-fuelpumpguide.htm
Yeah, they tested a Walbro at 3 bar and got 262lph
Testing a standard pump will be a pain
