Old 19-01-2007, 18:35
Default silvia balljoint dimensions
OK chaps, bit of a weird one this, but im looking for a bolt on balljoint with the same taper as the uprights im using (not Nissan or even close!) and came across these on ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.d...ssPageName=:IT
Are these the same as the S12, and if so can someone measure the taper diameter. I need the diameter at the bottom of the taper, diameter at the top of the taper, and the distance between the two.
Cheers
CNH
Old 19-01-2007, 19:12
16.2 mm at the top and 19.5mm at the bottom,
Old 19-01-2007, 20:43
Ive got that very ball joint at home.
The S13 is the same size taper as the S12 as well
Old 20-01-2007, 14:00
cheers guys, unfortunately i need 12.25 to 14.5 ish
thanks for checking tho.
