Old 10-03-2007, 02:22
alundra alundra is offline
Default Setting the A/F ratio?
I'd like to set my air fuel ratio.
My mods:
MK 1,5
Stock ECU management, stock injectors, K&N filter in box, 2.5" piping+ intercooler, polished head, cold spark plugs, T2 at 0.6 bar with MBC, 2,5" exhaust, 98 RON, Luk 13 clutch, 40 mm dropped etc...
I have a digital A/R ratio gauge, idle 14.6, full throttle/full boost 10(can't read under...). i'd like to set up like 12.5/13 at full boost.
What can I use? (cheaper to higher cost)
Cheers.
Old 10-03-2007, 11:44
Maximilian's Avatar
Maximilian Maximilian is offline
Maximilian is on a distinguished road
Apexi SAFC-II, can't say much about it but i know there are several writeups for using them on the S12 CA18ET.
Eventually you realize that your time can be better spent on more productive activities than beating your head against the wall arguing with density.
Old 10-03-2007, 14:15
Thanks for reply:
Who test this?
http://www.hksusa.com/categories/?id=1920
Old 11-03-2007, 10:01
s12Rob's Avatar
s12Rob s12Rob is offline
My mods:
MK 1,5
Cheers.
how are you running a air/fuel guage?
Old 11-03-2007, 10:13
I've got a a/f gauge:
The best way to alter the fueling, is to remap the ECU.
Alundra why don't you turn the boost up (if the turbo allows) and see if it reduces to say 11.5:1.
The reason why they run so rich is because they are mapped without an intercooler ie they make it rich to run safe
Old 11-03-2007, 11:00
s12Rob's Avatar
how much did that kit set u back and is it for sale, lol
Old 11-03-2007, 11:52
Im struggling with this right now as well. I have a dash mounted A/F gauge but it lies to me through the medium of flashy LEDs If you turn all the accessories in the car off then at idel it shows rich, but if you turn the lights and fans on then it nearly shows lean? is this strain on the engine via the alternator, or is it that the voltage supply to the meter should be regulated at 12v
Im thinking of visiting a tuner to see if they can get my car back nearer where it should be but the only adjustments would be the AFM, throttle bypass valve (idle) and the timing. Would this be enough to set teh car up better than current (it cant get much worse)
Currently running about 20p per mile! or about 21mpg. I would really prefer 25mpg which would be about 17p per mile or a saving of £372 per year (so I can spend that much making the change and be no worse off. My bluebird turbo (same engine,heavier car, intercooled, more restrictive exhaust) was <14.5p per mile or 29mpg so it should be achievable.
Old 11-03-2007, 12:59
that is a narrow band gauge running from a narrow band sensor (what are you using? the s12 doesn't have one as standard) they tell you nothing at all.
sounds like you have a boost leak to me
Old 16-03-2007, 18:16
what make is that gauge mart.does it come with softwear.
Old 16-03-2007, 23:47
it's a VEMS kit, you can get all the vems software free by download
