Old 20-04-2007, 12:34
alundra alundra is offline
Default Help to choose my starter
Ok, my starter is dead and here in France reconditionner factory are hard to find.
I found a website which sell them, in France, seems two models in S12, mine mk1,5 with mk1 motor.
My question is: is it interesting to fit the most powerfull one (1 vs 1.6)
http://www.altdiscount.com/affichear...mmat=0&moteur=
Oh, i'll take out the starter this week-end? Who've done this, easy?
Cheers.
Old 20-04-2007, 12:54
Mine has the later 1.6kw version.
Whats actually wrong with your starter motor?
Old 20-04-2007, 13:45
"clic" sound, wires connected ok, no dust on it, checked relays in black box near battery, battery charged, no ecu fault code (for neutral position and other possiblities).
It appears after a track day suddenly no sign before this...
Old 20-04-2007, 13:52
ChEsTeR ChEsTeR is offline
Use something hard and knok a few times iat the back of the starter. If it helps and te car will start u are 100% sure its time to replace it.
Old 20-04-2007, 14:23
Thats an issue with the starter solenoid. It needs rebuilding and cleaning. I used wd40 to lubricate but i heard its better to use graphite.
Old 20-04-2007, 14:49
But alundra says tht selenoid works. The click sound. It may be that the brush the things that brings voltage to the commutator locked.
Old 20-04-2007, 18:37
Not incredibly difficult but here's a few pointers:
Disconnect the battery
Remove the bracket on the side of the inlet manifold
Remove both wires, ones a plug and the other is held by a 10 or 12mm nut.
Get a 14mm spanner preferably a rachet spanner
Remove the 2 bolts holding it to the gearbox
Remove the cylinder on the side of the starter, this is the solenoid. Its held by 2 long thin bolts. Be careful with the clip but chances are it will spring out.
Clean up the solenoid, refit and enjoy a new starter motor.
Probably looking at 1-2 hours to do it
Old 21-04-2007, 10:45
or get one for an S13 like others have done which are lighter!
Old 21-04-2007, 11:20
Still hurts when you drop them on your feet though lol.
All the time I've been in France I've never seen a single S-chassis car so can only imagine getting parts is near on impossible.
Old 21-04-2007, 15:47
Ok,
With your advices, remove the starter was easy, thanks!
Some pics:
I saw some new/reconditioned starter, in France, but:
-they have a "cover" on gear area: http://www.altdiscount.com/affichear...mmat=0&moteur=
According too me this fit: http://www.altdiscount.com/affichear...mmat=0&moteur=
I found this site too: http://www.woodauto.com/Unit.aspx?Ma...I&Ref=S114322A
