Old 08-06-2007, 18:42
kms racing kms racing is offline
kms racing is an unknown quantity at this point
Default afr gauges
iv just brought a afr gauge ,then found out i need a lambda sensor to make it work ,has any one got any bright ideas on wiring a lambda in to the system
any help much aprecated
Old 08-06-2007, 20:17
Just use a single wire lambda and get it fitted into the exhaust close to the turbo downpipe.
I used to use one of the cheap gauges, and they're not really worth using, they only show a narrow part of a wide possible range of fuel mixtures. I now have a wideband system.
Old 09-06-2007, 17:41
doski's Avatar
doski doski is offline
you can get a norrow band lamda off a face lift s13, i got one to run the o2 attachment on my turbo timer
Old 12-06-2007, 17:47
cheers chappys, how do i go about wiring in a lambda
i guess the single wire lambda's earth out throught the exhaust and the wire is the signal wire which would go to the signal wire on the gauge , it on a autogauge afr gauge
cheers nick
Old 12-06-2007, 18:09
Yeah exactly that
Old 13-06-2007, 17:59
brilliant ,cheers for your help
