Old 27-06-2007, 19:32
kms racing kms racing is offline
kms racing is an unknown quantity at this point
Default cluch
i have just brought a s13 cluch ,i was just wondering what the job is like on them and any are there any hints to make the job easer
cheers nick
Old 27-06-2007, 19:40
Removal of the gearbox whilst on your back is a pig but worth doing to save the garage fitting costs. The main problem I found was trying to get the input shaft to go into the clutch plate. A hint I've found was to loose the Two bolts on the engine mounts on either side. BEWARE Not to undo the actual mount ones as its filled with Oil and it will seep out and they will be knackered. Just the ones that will enable the engine to be tilted at the from ie the back downwards which an assistant can do while you get the input shaft in by wriggling the box about
Old 28-06-2007, 02:45
very easy, just remember to disconnect the exhaust so the engine can rock backwards and use a decent alignment tool on the clutch
Old 28-06-2007, 09:09
mr_turbo's Avatar
mr_turbo mr_turbo is offline
very very easy clutch todo mate undo prop n exxhuast then the starter then the 4 bolts holding th ebox on do top first as can be fiiderly! then once they off hold the box up with a stand then undo gearox mount n pull off very simple the release bearion does need preshin on thou dont 4get to take off slave cylinder also
Old 28-06-2007, 10:09
I found that laying under the car with my head at the engine and my feet pointing towards the diff you could use your knees and hands to line up the gearbox accurately (hands on the bell housing and knees on the gearbox), I didn't even have remove the exhaust or loosen engine mounts (although our ones could be a bit worn now I guess). You have to twist the gearbox towards the drivers side to clear the bulkhead when you first offer it up.
Old 28-06-2007, 15:22
mr_turbo's Avatar
im a lucky one i have ramps so aint had the plesure
