Hey,
How easy / expensive / worthwhile is it to fit s14 discs and calipers to the s12? Only i've read about people doing it quite alot recently and would quite like the upgrade. Ta. |
I've got the FOUR pot calipers fitted to mine on standard size Silvia discs which are drilled and grooved 274 x 22mm. S14/Z32 discs are 280x30mm but won't fit anyways as the are a push on type and are 5 stud. Silvias bolt on from the back of the hubs so are different. I think you can fit them If you use S13 hubs though. I wanted to fit the 4 pot calipers but could not be bothered with the hassle of the discs. They definately make a hell of a difference though.
sounds good, thanks.
