Old 14-02-2009, 16:08
WM-S12's Avatar
WM-S12 WM-S12 is offline
Default Magnecor HT leads
right i've had a set of Magnecor HT leads for a while now, blue performance ones. The other week I got a call from a representive from Magnecor asking me about my s12 and the HT leads if they do fit properly, guy sounded like an aussie but he was saying someone else they sold S12 ht leads to has informed them they don't fit?
was told they've only made a few but only reason I can think of is if the guy's swapped the engine, or the distrubitor is in a different place...ie...different country different engine model. Set I got fit perfectly in an L shape and use the original plastic hooks
no idea but surely the ca18det would need longer ones as the engines that bit bigger. Not sure, just a random thought.
Old 16-02-2009, 08:14
lmrdave's Avatar
lmrdave lmrdave is offline
Mine were the bigger core ones and they were a bit tight to fit, but fitted ok.
Old 16-02-2009, 09:17
Some of those leads look too short Dave (to clip in the normal places anyway)
I bought a 8mm lead set for a V8 which was only about £25, enough to do 2 cars too. You have to make up them up to length but it's damn cheaper than Magnecor.
Old 16-02-2009, 11:15
WM-S12's Avatar
wasn't that expensive, plus I bought them along side a new set of spark plugs. Got them both on the same day and simply installed them straight away without a fuss.
aye the 8mm red ones were classed as "Race/road" If I'm correct, mine are 7mm performance range.
Old 17-02-2009, 08:58
lmrdave's Avatar
Yeah, those 7mm blue leads fit alot better. Mine are a bit messy but they work, so I'm happy
I get a good deal through my motor factors and I was feeling flush that day
Old 09-03-2009, 14:17
s12sweden's Avatar
s12sweden s12sweden is offline
s12sweden is an unknown quantity at this point
WM-S12 : much nice engine room you have on yours s12
Old 19-05-2009, 23:25
you need to seperate the intercooler from the rad mate.
Old 20-05-2009, 08:00
lmrdave's Avatar
I would if there was room! Thanks for pointing out my muppetry!
Best I can do is isolate them with a strip of neoprene, intercooler can't go any further forward and rad can't go any further back!
Old 09-03-2009, 14:18
s12sweden's Avatar
so nice
Old 15-03-2009, 14:39
WM-S12's Avatar
lol, cheers bud. It could do with tidying up but it's purely just comestic at the moment. Soom to be filled with an intercooler so that should cut the space in the engine bay down.
