Old 05-03-2006, 17:15
GWtaylor GWtaylor is offline
GWtaylor is an unknown quantity at this point
Default What do i look out for
Hi ppl
Want to buy my first s12 but no nothing about them. So what would the best things to look out for on a one and is the a thread anywhere telling the spec and models?
I know i sound like a real dummy but i really have no clue about the s12
Old 05-03-2006, 17:34
datdrift's Avatar
datdrift datdrift is offline
there was a thread on sxoc recently about what to look out for, and as for specs/models most come with the ca18et 1.8 single ohc turbo, but a few early ones came with the 2 litre dohc fj20e.
and things like power steering/elec windows/elec mirrors/sunroof/central locking were optional extras.....
after f reg or summit they were facelifted and called the mk2, revisions included bigger front & rear bumpers, different gearbox and different front grille, etc
Old 05-03-2006, 17:49
Did the 2 litre dohc fj20e come with a turbo because the one i'm after is the turbo model
Thanks
Gary
Old 05-03-2006, 17:51
datdrift's Avatar
not over here, in japan they relesed the fj20et 2 litre turbo.
but if you are after the turbo its the 1.8, farly easy to get 200bhp and light and compact you would be lucky to come accross a 2.0 anyway, as they are fairly rare
Old 05-03-2006, 17:58
Ok thanks mate
Old 05-03-2006, 20:44
Check the following....
Sills for rust
bottom of the wings under the mudflaps for rust
Check that the rear brakes are not siezed
that the indicator stalk is working correctly/Both flip up lights are working
there are no manifold to head studs missing or that the gaskets are blowing
Listen for gearbox 'whining'
Check the fuel tank for leaks
The rear boot lid struts hold the boot lid up
Play in the windscreen wiper mechanism
check the engine for excessive rocker/crankcase pressure. remove oil cap while engine is at idle. it should not drop more than 150/200rpm
While test driving check the clutch bite, gearbox sycromesh is smooth and the turbo is operating properly with no smoke on gearchange/under boost. Also check that there is decent oil pressure
Standard the turbo is set at around 6psi and oil pressure should be at around 40psi at 2000rpm
